Latest post 05-17-2008 10:59 AM by martpendle. 8 replies.
Page 1 of 1 (9 items)
  • 05-17-2008 7:06 AM
    HDMI to DVI Cable Problems
    Hi
    I hope i am going about this in the right way!
    I am having problems with connecting a media center pc that i have bult to my TV.
    I  have a Beovision 7 and i am using a HDMI to DVI cable to connect the pc to the TV. (HDMI at the pc and DVI into the TV)
    I have set all the connections to "none" except for AV4 which is PC and AV3 which i have set to my digifusion set top box (connecting by scart)
    The problem is that the TV is not detecting the PC at all!
    Any help would be much appreciated
  • 05-17-2008 9:07 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: HDMI to DVI Cable Problems
    Hi
    Entering in the AV4 connection menu, VGA is Active? It has to be to see your PC in the screen.
    Regards
    Quim
  • 05-17-2008 10:00 AM In reply to
    there is no VGA active/inactive option, audio and IR sockets are the only other options
  • 05-17-2008 10:17 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    What happens when you push PC on your Beo4? TV changes to a PC mode?
    Quim
  • 05-17-2008 10:21 AM In reply to
    There is no PC option, even when it is plugged in an turned on, it does not appear on the "list" on the remote control screen
  • 05-17-2008 10:24 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You have to add the PC option in your Beo4. Press Standby and List buttons at the same time. You will see ADD? in the Beo4 screen. Press Go and then List till PC appears on the screen. Press GO and PC function will be added in your Beo4.
    Quim
  • 05-17-2008 10:40 AM In reply to
    thank you so much! i now have output!!
     one last small question, when the pc gets past bios i get an odd output full of lines, this then resolves itself when the OS boots up, this makes it very hard to navigate live cd's
    is there any way of fixing this?
    Cheers
  • 05-17-2008 10:46 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You are welcome, glad to see it works now.
    I am sorry i can't help you with this question. Maybe another member will do it.
    Regards
    Quim
  • 05-17-2008 10:59 AM In reply to
    ok, thanks for all your help
