Latest post 05-21-2008 8:09 AM by Michael. 2 replies.
Page 1 of 1 (3 items)
  • 05-15-2008 10:00 PM
    Beosystem 1 - no video (a dumb question)
    I just got my BS1 back from the repair shop after having some work done on it (HD mod and chip upgrade) and I cant get any video output (sound works ok).
    I have tried a couple of different monitors with no success. Being ever hopeful (and not wanting to ship it back unless I have to), is there something  I should be doing with the BEO4 remote that turns the video output on the VGA plug on and off  ?
    If not, its back in the box and on its way back to the repair shop cross country.
    Mike
  • 05-20-2008 3:14 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beosystem 1 - no video (a dumb question)
    Hi Mike and welcome to BeoworldSmile
    So sorry no-one has got back to you on this, we had a problem with the server over the last couple of days.
    I can't help you on this, but by bumping this for you, someone might see it and help you out.
    By the way, there is no such thing as a 'dumb question' on here!
    Andy T.
    Poor me, never win owt!
  • 05-21-2008 8:09 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Nothing I know about with the Beo4.  I recall that the set up was always a little tricky and that the BS1 didn't like things changing (new sources, inputs etc.) while already on.  Your source settings could be messed up to some degree.  Try plugging a source into the single input on the front of the box and see if you can see it ( this is a temporary input that is automatically selected when it receives a signal.)  If this works then check all your input settings to make sure they are correct.  It might not work for you but I used a computer CRT for viewing and setup before I got my plasma installed.
        If none of this works then you might want to try service to see if there is any steps they can walk you through before you ship it anywhere.
    -Michael
