Hi
I have finally decided to buy a BV5 HD-ready and then move the 32" Avant to the kitchen.
I know that many would tell me to buy the BV7-40 HD, but I really like the design of the BV5 and the size of the BV5 is also a factor here.
I have two on hand but what is the difference from the two type numbers. Is it only the country code or is it also colour code, SW version etc that depends on the type numbers?
BV5 HD ready Type 8948 SW ?
BV5 HD ready Type 8913 SW 16.2
I live in Denmark and hope it would be possible to use one of these type numbers
Is there any one of the latest BV5-HD ready made with HDMI connection or are all of them only with 1 DVI connection?
Anders
