Latest post 05-30-2008 1:57 PM by Beolab1. 5 replies.
Page 1 of 1 (6 items)
  • 05-13-2008 4:24 PM
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Is it possible to change Beogram 8002 120 Volt to 220 Volt?
    With the help of Graham and the service manual on Beoworld, I turned a 120V Beogram 7000 into a 220V Beogram 7000, by changing the tappings and soldering a new powercord to the transformer. The fuse was already a 700mV, so did not need changing. Now it works perfectly. Thanks again Graham!
    Now another one: Can a U.S. Beogram 8002 (120V) be modified to be a European Beogram 8002 (220V) in the same way? I checked the Beogram 8002 service manual, but it looks a lot more complicated than the Beogram 7000 one. Thanks in advance for your suggestions!!!
  • 05-13-2008 4:33 PM In reply to
    Re: Is it possible to change Beogram 8002 120 Volt to 220 Volt?
    Glad to help with the 7000 but I'm afraid the 8002 is outside of my experience. I'm sure Dillen will be able to help as I believe he takes these apart with his eyes closed!
    Good Luck with it.
    Regards Graham
  • 05-15-2008 1:26 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Yes, the transformer is a plug-in module. You need to get a 220-240V transformer module to replace the 110-120V one you have.
    The transformer pushes up from under the Beogram when the aluminum lid is open and the mains lead is gently guided out from the corner of the aluminum lid hinge.
    The Beogram 6006, 8000 and 8002 transformers are the same.
  • 05-15-2008 8:23 AM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks Martin! It think it will be pretty difficult to find a 220 V transformer, since all the models that you mentioned have become so rare. But i'll take up the challenge.
  • 05-30-2008 11:31 AM In reply to
    Get in touch with Dillen.
    I gave him my former 220 volts BG8000 transformer about 3 weeks ago and it was a working one just that I did not need it anymore.
  • 05-30-2008 1:57 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks a lot Friedmett, but I just found one this week!
