Latest post 05-13-2008 4:31 PM by mbee. 10 replies.
Page 1 of 1 (11 items)
  • 05-13-2008 2:08 PM
    Beolab 3 upgrade question
    I know this was discussed earlier but I could not find the thread.  I have a pair of Beolab 3s that I purchased when the speakers were first introduced.  Is there a MKII version or is there an upgrade?  If there is a new version, can the original Beolab 3s be upgraded to the new version?  Thanks.
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 05-13-2008 2:21 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: Beolab 3 upgrade question
    AFAIK, the BL3 has not been upgraded. The only thing I think to remember is that the AL was made of aluminum a the launch, but later they swapped to plastic. Still, I'm note sure about this...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-13-2008 3:00 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    PLASTIC ALT??? I hope that's a joke...
  • 05-13-2008 3:04 PM In reply to
    • Alex
    • Bath & Cardiff, UK
    • Posts 2,990
    I'm not quite sure about that, I've heard it before though. The BeoLab 3s overall feel fantastically well built to me, and the ALT always feels very metallic.
    If they have swapped it for a plastic ALT, then I can't say it's affected the quality or feel of the speaker at all...
     Weekly top artists:
  • 05-13-2008 3:29 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Alex:
    I'm not quite sure about that, I've heard it before though. The BeoLab S overall feel fantastically well built to me, and the ALT always feels very metallic.
    The ALT it´s 90% plastic fantastic! The thin top and bottom plate of the ALT lens housing is made of aluminum, but it is plastic in between though...
    BL8000 MkII Black
  • 05-13-2008 3:34 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    Beolab:
    Alex:
    It´s 90% plastic fantastic! The thin top and bottom plate of the ALT lense housing is made of aluminium, but it is plastic in between though...
    What about changes/ upgrades? Are there different versions or only one?
  • 05-13-2008 3:44 PM In reply to
    • Beolab
    • Sweden
    • Posts 535
    Tom:
    Beolab:
    Alex:
    BL8000 MkII Black
  • 05-13-2008 3:59 PM In reply to
    • Alex
    • Top 500 Contributor
    • Southern CA
    • Posts 137
    Sorry to correct you but there is an upgrade... new type numbers were assiged for the BeoLab 3 range with the upgrade.
    -Alex
  • 05-13-2008 4:01 PM In reply to
    There is a Mark II version of the Beolab 3 and they were assigned new Type numbers of 687X
    As I understand it, B&O improved their production process and used some new materials in the Mark II product which I assume was to get the product cost down. However, by doing this, it changed the performance of the Beolab 3, so to ensure they kept the same sound performance and frequency characteristics from the loudspeaker, the cross-over components were modified
    These changed components which effected performance were:-
    • Woofer
    • Main chassis PCB
    Other items already highlighted in the previous posts were also changed, but they did not actually effective the performance of the speaker.
    In my view, if you had a Mark I version, you would not wish to upgrade it to a Mark II even if you could.
    Regards Keith....
    • Tom
    • Luxembourg
    • Posts 3,175
    Alex:
    Thanks, Alex! So there has been an upgrade, but no visible one.
  • 05-13-2008 4:31 PM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    No AUDIBLE one, I hope Big Smile
