villarsch: My apologises if this item has already been covered, but after having trouble with the Sky HD box I have been told by Sky Technical that I should not have a Scart connection between the Sky HD box and the TV. When, however, I disconnected the Scart, the TV had no sound on Sky. When I reported this to Sky, they said that the Scart was in conflict with the HD lead, and that I should disconnect the HD lead and get Sky HD via the Scart.
Has anyone else heard of this and, if so, can and does the Scart carry the HD to the TV?
If it doesn't work, how does one get a non-Scart HD lead to work? Any suggestions would be much appreciated.
As usuall Sky are giving you all the wrong advice. You have a few options of how to set up your system, but in all cases the scart needs to be connected otherwise you STB controller will turn you box off fromm time to time.
Scart only - not really a good option because as already posted above, it will not deliver a HD image.
HDMI - DVI + scart - because the Beovision 7 uses DVI the audio is carried through the scart.
HDMI-DVI + scart + digital audio cable - probably the best option, digital video and audio but the scart must still be connected.
YbPbPr + scart - again ther is no audio via th YbPbPr so the audio is through the scart.
YbPbPr + scart + digital audio cable - another very good way of doing it but picture not quite as good as HDMI on bigger screens.
