Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Tom:Is it possible, to create a button on the Beo5 that opens the DVD-tray on a BV7?
Hi Tom
Sure, it is. Just add the Eject order where you want in your Beo5. It works fine.
Quim
Quim43: Tom:Is it possible, to create a button on the Beo5 that opens the DVD-tray on a BV7?Hi TomSure, it is. Just add the Eject order where you want in your Beo5. It works fine.
Thanks! I'll check that with my dealer.
Poor me, never win owt!
Jandyt:......and then you'll have to get out of your armchair and walk over to change the DVD
But you can Block the SensiTouch and hide your Beo5 from children, so they can't open it to insert something bad for your TV, as they like to do
Regards
I am always terrified when my nephews run around my TV, but till now, I have been lucky
