Got my pair of BL 5000s, from a guy who had bought them used but never tested them or seen them working - he didn't have any other B&O gear to test them with. Here's the situation: I hook them up to power, and to my BM 3500 via Powerlink. This is exactly the same hookup that works perfectly with my Penta 2s. When power is applied, the red LEDs light up in both 5000s. I move the switches from Standby to Audio. Still red LED. I play a CD on the 3500 system; the 3500 powers up. The BL 5000s power up, both of them. But all that happens is that the red standby LED goes out, there's a faint 'click' from the relay inside, and the data display lights up very faintly, as if with a backlight. That's it. Nothing. Nada. No sound, no data on the data display. Playing with the A/L/R mode switch doesn't help (shouldn't make any difference with Powerlink anyway). Tried different cable positions, tried one speaker at a time, even tried with a 5000 on one Powerlink, a Penta on the other. Nothing changes - always the above response. Always, the Penta(s) work perfectly.
The Beomaster and cables drive the Pentas perfectly so I don't see there being any problem there. The fact that both speakers behave exactly the same suggests to me that, somehow, somewhere, I'm doing something stupid; it's unlikely they're both dead with the same fault. (unless maybe it's a power supply fault - perhaps in a previous life they both got zapped by a power surge or something?)
 Any thoughts would be appreciated.
 Mike
