Latest post 10-31-2011 7:02 AM by frog. 22 replies.
Page 1 of 1 (23 items)
  • 05-09-2008 10:52 AM
    BS3 update: lost Panasonic RS232 control
    I just got my BeoSystem 3 back from the shop with a SW upgrade from 2.0 to 4.17.  Now my commercial Panasonic TH-37PH10UK no longer turns on/off from the RS232 (Monitor) connection.  Is anyone out there having luck with this combination?  I was hoping I'd get lucky and gain sensor-based auto-contrast.  I tried the D9 and D10 BeoVision 4 settings.
     -- Paul
  • 05-09-2008 11:13 AM In reply to
    Re: BS3 update to 4.17: lost Panasonic RS232 control
    Have you disabled the panel autodetection?
    Marcus
  • 05-13-2008 9:16 AM In reply to
    marcus_m:
    Marcus
    I've never ventured into the service menus.
  • 05-13-2008 2:31 PM In reply to
    That was the only way to get my TH50PH10 to work with BS3.
    Good luck, Marcus
  • 05-15-2008 5:06 AM In reply to
    Hello, i've got the same problem with a customer so, do you find a solution, we've tryied to cancel the autodetection withwout result.
    The customer as also lost the autocontrast.
    Perhaps it's interresting to make a little box who will control the PDP.
  • 05-15-2008 8:54 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    I think it would be a shame to have to make a little box controling the PDP, as the Beosystem 3, this very big box, is advertised as the "stage manager", controlling everything... If it's meant to sell some BV4, IMHO it's a mistake, as people connecting a Panasonic plasma to a Beosystem 3 simply doesn't want to pay so much money for just a screen, outdated 6 months after its release. Customers buying Beovision4 and people buying Bs3+Pana are not thinking the same way.
    So I hope that it's just a new bug which will be corrected VERY soon!
  • 05-15-2008 10:54 AM In reply to
    off course but i think that the situation is like that.
    You must have a B&O screen if you want all the function
  • 05-15-2008 11:05 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    The question would be how the BS3 recognizes the Panasonic Panel as BV4 instead of a TH-50 something.
    The DVI ID tells the connected System what type, name, resoltion etc it is. For my understanding this is done by the DVI module (e.g.the name/type number of the module is shown and not the display if you check this in the service menu).
     So would a B&O spare part DVI module solve the problem?
     Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 05-15-2008 11:35 AM In reply to
    yes the pdp is identified by the dvi.
    i think if you change the dvi input socket you will have the same problem.
    remmember when we had to update the PDP D7 (only VGA) monting dvi kit, we had to update two hex files contained in hardware.
  • 05-15-2008 12:41 PM In reply to
    Last Summer, a dealer told me that B&O offered a DVI card that might give Panasonics the identity of a BV4, which I was considering to get auto-contrast working.  I'm wondering if this would fix the current issue.  I'd prefer not to do this though, as the card is, I'm sure, a bit pricey.
    My dealer is currently looking into solutions.  I'll keep you posted.
    -- Paul
  • 05-17-2008 9:10 AM In reply to
    We found a solution for the on/off control of pdp
    we control the rs232 with the ir input
  • 05-17-2008 3:29 PM In reply to
    MADSYSTEMES:
    The B&O BV4 plasma screen actually is a Panasonic screen. You can even get access to the Panasonic software over the service menu. When I replaced my Beosystem 1 by a Beosystem 3 my BV4 50" plasma had to receive an additional software upgrade.
  • 05-17-2008 6:08 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    We also have the same problem with a client here and we're pretty baffled.  Beyond losing control via RS-232 it seems that every time the serial cable is even plugged into the panel it shorts the entire thing out.  If the RS-232 is plugged in the Panel's OSD ceases to show up using the Panasonic remote.  We figured that obviously since the 232 isn't working we'd go back to using the IR control, but unfortunately we weren't even able to get control back with the use of IR.  Should turning off the autodetect of the panel affect IR control or would that only be relavent for RS-232 control?
    Puts my mind a bit at ease at least knowing that someone else has bumped into a similar problem and there may be a solution somewhere in sight!
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 05-17-2008 6:11 PM In reply to
    • Alex
    • New York, NY
    • Posts 176
    beopaul:
     $380USD but as far as I know there isn't a difference between the B&O one and the Panasonic card for about the same price.
  • 05-20-2008 5:04 AM In reply to
    i haven't only the sofware for the upgrade of pdpd7
    i don't think that it is a B&O software available for the other pdp
  • 06-03-2008 1:56 PM In reply to
    • kawo
    • Posts 516
    Hi there, is there any update on that issue? I would like to update my Bs3 but not surebecause I don't want to loose the RS232 control of my Panasonic plasma.
    Karsten
  • 06-03-2008 2:49 PM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    I just got the 4.17 update and the box still drives my Panasonic TH50-HD7E  no problem.
  • 10-11-2008 7:00 AM In reply to
    • M4SPM
    • Not Ranked
    • Burnley, Lancashire United Kingdom
    • Posts 38
    I have the exact same problem and was wondoring if anyone has come up with a solution for this
  • 11-18-2008 11:18 AM In reply to
    Was this ever solved?  I have a similar screen (42PH10) and was hoping to use it when I eventually save the cash to buy a BS3.
  • 11-18-2008 5:44 PM In reply to
    • M4SPM
    • Not Ranked
    • Posts 38
    Two work arounds
    1. Switch Autodetection off and select BV4-50 D9 as display
    2. If you have a Beo 5 Remote there is a download which can easily be added to your Beo 5 remote by your dealer on Beoworld which allows control of on and off switching of Panasonic Plasmas
  • 07-08-2011 12:35 PM In reply to
    Re: BS3 update: lost Panasonic RS232 control
    Bumping this thread up.  Has anybody successfully used a B&O DVI card to get a Panasonic commercial plasma display to work with auto-contrast?
    -- Paul
  • 10-29-2011 6:24 PM In reply to
    • frog
    • Posts 191
    How do you switch autodetect off - can't find anywhere in the menus - the Configuration menu is blank.
  • 10-31-2011 7:02 AM In reply to
    • frog
    • Posts 191
    Got it - it's red GO on the options menu.
