1st March February 2012
Latest post 05-09-2008 1:50 PM by Jandyt. 7 replies.
05-09-2008 4:40 AM
demonell
- Joined on 03-31-2008
- Cheltenham
- Posts 44
Am I missing something here...... As far as I can tell the Mk1 and Mk 2 versions are the same, apart from the current version you can add up to 8 rather than 6 handsets, and the current version you need to buy a separate PSTN box (another piece of kit to try to hide away), whereas with the Mk1 version the PSTN is neadly encapsulated in to the pyramid base charger / table stand. Is there any advantage to the Mk 2 version which I'm missing, which might pursuade me to spend the extra cash? Thanks
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
You can use a hands free with Mk II. Not possible with Mk I.
wirralsimon
- Birkenhead, UK
- Posts 1,253
I amguessing that Keith will be a along in a minute, he is the expert on the Becom 6000. The Mk1's and Mk2's are quite different underneath. Simon demonell:Am I missing something here...... As far as I can tell the Mk1 and Mk 2 versions are the same, apart from the current version you can add up to 8 rather than 6 handsets, and the current version you need to buy a separate PSTN box (another piece of kit to try to hide away), whereas with the Mk1 version the PSTN is neadly encapsulated in to the pyramid base charger / table stand. Is there any advantage to the Mk 2 version which I'm missing, which might pursuade me to spend the extra cash? Thanks
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
If you already have a Mark I Beocom 6000 and it is working correctly, then there is little benefit from a general user viewpoint unless you wish to use the hands free option. There is in fact three (3) versions of the Beocom 6000:- - A Mark I version
- An updated Mark I version which provides all the functions of the Mark II including the same software, EXCEPT it does NOT have the earset socket and needs to be charged on a Mark I charger.
- A Mark II version
The key differences between a Mark I and Mark II are:- - CLI (Caller Line Identification) works in all locations where available, there are some issues with the Mark I
- The Menu is much more user friendly.
- The internal intercom feature is easier to use (my view)
- The conferencing facility
- Display is in upper and lower case text
Also, if you get a fault on the internal module, you cannot have it replaced, it must be upgraded with a B&O upgrade kit.
Page 1 of 1 (8 items)
