I have a problem! I have a B&O solution with BeoSound 4 as an audio master, one BeoLab 3500 in one Linkroom and a BeoLink Active with IR-eye in another room.
In main room the A.AUX is connected to a common DVB-T receiver and the there is no problem selecting A.AUX from the LIST on Beo4. The same method is used when selecting A.AUX in the Linkroom with BeoLab 3500, also works fine. But when I try do the exact same thing in the linkroom with the BeoLink Active nothing happens. I can select CD, A.MEM, RADIO with no problems.
I've also tested to activate A.AUX i main room and then go to the Linkroom with the Beolink Active and press the PLAY button on the IR-eye, this will activate A.AUX and everything seems to function correct.
 But I can't activate A.AUX from the Beo4?? I can see that the IR-eye is receiving the IR-signal.
Is there anybody who knows something about a solution or where the problem might be??
