Latest post 05-09-2008 9:38 AM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 05-08-2008 10:09 AM
    beovox speakers
    I do hope someone will be able to help. I have recently become the proud owner of my parents old b and o sound system. I do not wish to use the tape and record deck but would love to connect the speakers to my existing jvc sound system. The b and o system is at least 30 years old and hardly used, but the speakers have foam rot and I want to replace I believe its called a new driver in each one, where do I get this from, is it expensive? the speakers are S55T6426 thank you deborah
  • 05-08-2008 10:21 AM In reply to
    Re: beovox speakers
    Welcome to Beoworld.
    The S55 is a pleasant smaller speaker but does indeed suffer from foam rot. I would suggest having the surrounds replaced rather than the drive units. If you are in the UK, I would suggest Recone Lab as being able to this for you.  I suggest ringing them as they are not great at email!! I would consider having the capacitors in the cross over changed at the same time - makes a big difference! They age and the sound becomes slowly more dull.
  • 05-09-2008 9:05 AM In reply to
    Re: beovox speakers
    thank you so much for that. I live in Buckinghamshire UK. so is recone lab the closest to me?
  • 05-09-2008 9:38 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: beovox speakers
    I agree with Peter re:- getting them refoamed & the capacitors replaced. Replacement units are impossible to match with the originals,
    Reconelab are in Huddersfield.
    Chris.
