Latest post 05-08-2008 11:38 AM by nobby. 3 replies.
Page 1 of 1 (4 items)
  • 05-08-2008 8:02 AM
    Cleaning a Beovision 1
    Hi:
     I know that there is a section of the site dedicated to this. However, I am reluctant to do anything without asking anyone as the "be careful if you have anti-reflective coating" statement (not verbatim) concerns me.
     I have several "snotty" marks on the glass of the TV and want to clean them off. I was thinking of using alcohol wipes like those used to clean PCs and stuff. Would this be OK?
    Graham
  • 05-08-2008 10:03 AM In reply to
    Re: Cleaning a Beovision 1
    My advise would be slightly damp cloth with mild detergent to get the serious grease off, then a damp cloth to remove the detergent, then a tea towel with lots of elbow grease before the water dries off. Gets great results on my avant, AV9000, AV5 and MX Tvs ... BV1 should be the same.
    Neil
  • 05-08-2008 10:54 AM In reply to
    Hi:
    Thanks - mild detergent = fairy liquid?
    Graham
  • 05-08-2008 11:38 AM In reply to
    Yes, but just a small drop.
