1st March February 2012
05-07-2008 1:36 PM
11048437
- Joined on 04-17-2007
- Posts 352
schematics RCA to Powerlink
hi, I would like to connect a Beosound 2 player directly to Beolab 3 speakers. Has anyone of you a schematics of this cable transformation? Thanks in advance, Constantin
Bulgarien
- Denmark, Vest Sjaeland
- Posts 201
Re: schematics RCA to Powerlink
Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
You can use both 5 and 7 pin DIN plug, its make no difference, in this set-up
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Does the BS2 have a phono connector?? Surely its a 3.5mm stereo jack?? Or do you mean a Beocentre 2??
11048437
- Posts 352
Bulgarien: Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
Thanks very much!! Do you think that Beolab 3 will Power On the moment I'll send signal on R and L channel? Constantine
11048437
- Posts 352
11048437: Bulgarien: Try these two link , all kind off schematics should be there... Peter Pans B&O adapter : ____________________________________________________________ Vil du kun se DIN stik, kabler / forbindelser, så se tegninger du kan lodde efter her. B&O DIN Adapter Cabel Connection. = Kun DIN forum:.
hm.........there are so many schematics there... I thinlk I'll need a voltage signal on the Trigger ........
11048437
- Posts 352
11048437
- Posts 352
11048437
- Posts 352
Puncher: Does the BS2 have a phono connector?? Surely its a 3.5mm stereo jack?? Or do you mean a Beocentre 2??
Hi Puncher, It's not about a beocenter 2, it's about a Beosound 2.... The ideea is that I bought a pair of Beolab 3 speakers on E-Bay from USA and the guy does not wanted to send them in Canada. I have found a solution: the guy will send the speakers in Plattsburgh, New York via UPS with the Hold For Pick Up option, and then I'll go there(88 km drive) to collect them. I would like to try them on place so that's why I'll need a way to verify them on place( in case I'll enter in Canada with them, then I have to pay 300$ Custom fees and if they «are not working, I'll have to send them back - difficult to have my 300$ back as I have to fill a lot of papers............It is a mess I know but the price of the BL3 was so good ..... Constantine
Hagen2000
- Joined on 05-08-2007
- Munich
- Posts 267
I would try the Beolab 3 speakers using their line input. In this case you won´t need a trigger signal to make the speakers work and you will only need a simple 3.5mm stereo jack to cinch adapter!
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
It's not the schematic to use.... You will need a mini jack and two "7" pin Din. Connect ground to pin 2 and 7, for the left speaker you connect the left sound signal to pin 3 and 5. and the same for right signal in the other plug. and then set the speaker to "line" and it will work.
Page 1 of 1 (10 items)
