Latest post 05-07-2008 9:52 AM by luckib. 2 replies.
Page 1 of 1 (3 items)
  • 05-07-2008 4:51 AM
    • luckib
    • Not Ranked
    • Joined on 05-07-2008
    • Posts 2
    • Silver Member
    Beogram 1500 (GR 1500 type 5230)
    Hi I've been lucky enough to become the owner of the above model. I know it's getting on in years but everything works well and it's in very good condition. Can someone please tell me what sort of drive the turntable has as there is a problem with the turntable speed, I can't get either the 33 or 45 the operate at the correct speed, both are down by about 10% ie. 33 runs at 30rpm and there is similar speed loss at 45. The 33/45 speed selector has a knurled centre piece which presumably should enable me to "fine tune" but this has litle or no effect!  Can anyone offer a solution?
  • 05-07-2008 5:24 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: Beogram 1500 (GR 1500 type 5230)
    The knob should adjust the turntable.  If you upgrade to silver or gold membership you should be able to download a user manual.  Shine a light over the turntable and a strobed effect should appear.  Use the knob to adjust  the speed (best done at 33).  If that knob is not changing the speed then there is a deeper problem.
  • 05-07-2008 9:52 AM In reply to
    • luckib
    • Not Ranked
    • Posts 2
    • Silver Member
    Thanks for your reply. My deck, which is most definately B & O only has the two speeds 33 & 45 there is no 78! And there is no facility to use a strobe as there is no marking on the turntable itself. The only way I can envisage timing is by using a mark on the outer ring of the t/table together with a stopwatch and counting the revs. Do you have any further suggestions?
