Latest post 05-07-2008 5:30 PM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 05-06-2008 9:01 PM
    Beovision 7100
    Hello everybody!
    I have just picked up a Beovision 7100 (1982-1983) and can't seem to get it working Sad
    The red indicator light does come on but the on/off switch doesn't stay in - and even if I hold it in, there is no image. Something must have happened in transit, as it was definitely working in the seller's house. I'm told the set has been serviced regularly and certainly looks like brand new. In your practice, dear B&O enthusiasts and pros, does this sound like something serious or fixable? Is it just the switch that has broken or possibly something more?
    Secondly, how does one go about connecting modern DVD players, VCRs, digiboxes etc to a vintage Beovision? The 7100 only has the antenna rod and the two 5-pin TAPE and AMP ports. Is there some sort of an adaptor available for Scart and/or S-video?
    Any advice much appreciated!
    Many thanks! Smile
    Filed under:
  • 05-07-2008 4:24 AM In reply to
    Re: Beovision 7100
    Hi, and welcome!
    I'm sorry I can't help with the functional problem, but I'm sure someone else can. Doesn't sound too serious to me, might be a loose contact after transporting the set.
    I don't think you have other options to connecting than using RF through the aerial input. Most VCR's have an RF modulator, so you can connect one of them and then other stuff to the SCART of the VCR (select "AV" or something on the VCR, and it would show the signal coming in through the SCART). I have a Philips DVD recorder, which would also do the job. Since the Beovision doesn't have any other kind of input, I'm afraid adding one would be quite a big job as it probably doesn't have any provisions for that inside, either.
    There are also stand-alone RF modulators, but getting one new will probably cost you more than a fully working old VHS!
    -mika
  • 05-07-2008 3:50 PM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Re: Beovision 7100
    The problem with using an old VCR is that it might not work, because of the Macrovision copy protection... When I hooked my DVD-player up to my old VCR, the picture got all scrambled, so I had to buy an RF-modulator...
    But I belive this doesn't affect all VCRs, just some...
  • 05-07-2008 5:26 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beovision 7100
    You can get a gismo that takes a Scart input and gives it an RF frequency so you can connect to the RF connection.
    CraigSmile
  • 05-07-2008 5:30 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beovision 7100
    Just found one on Ebay.
    RF Modulator
    CraigSmile
