Latest post 05-07-2008 4:11 AM by alcedar. 2 replies.
Page 1 of 1 (3 items)
  • 05-06-2008 4:20 PM
    Beogram 3000 earthing
     I have recently bought a Beogram 3000 from ebay complete with a convertor cable from DIN to phono jacks with seperate earth lead. My problem is I do not have a seperates amp to connect this too and therefore no earthing terminal. Is there any other way of earthing the turntable? I was informed by the seller that this earth lead is a must.
    Filed under:
  • 05-06-2008 4:24 PM In reply to
    Re: Beogram 3000 earthing
    What are you connecting it to? Any common earth will do - the chassis of what you are connecting it to should do.
  • 05-07-2008 4:11 AM In reply to
    Thanks for your reply Peter, The system I am connecting it to is in a wooden frame and is double insulated so I was a bit nervous about just connecting it to anything, found a screw which attachs directly through to the chassis though so should work fine. thanks again
    Al
