Latest post 05-07-2008 8:57 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 05-06-2008 7:01 AM
    Beocenter 9000
    Hi All,
    I've been searching this forum, but didn't exactly find the info I was looking for.Can anyone tell me the exact (philips) cd unit that is in the beocenter 9000/ I know it is nearly impossible to find, but would like to know what to look for.Thanks for your help.
    Robin
  • 05-06-2008 10:07 AM In reply to
    Re: Beocenter 9000
    It is a CDM2 but modified for use by B&O.
    What is wrong with yours?
    Regards Graham
  • 05-06-2008 5:39 PM In reply to
    Re: Beocenter 9000
    Hi, well actually...mine is (still) working (fine)...but the opening of the door panel is making a squeaking noise for about 2 seconds and then stops.....
    I'm afraid this might be the beginning of some issues.Must admit that reading on the net the forecast of a non reapairable cd player is not so convincing.But I might be just worrying too muchBig Smile
    any idea how to solve the door/panel issue ? Is it easy accessible ?
  • 05-07-2008 8:57 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 9000
    Welcome to Beoworld !
    To me it sounds more like a slipping belt. A new CD deck won't cure this fault. Cleaning, lubrication and a fresh belt is what it takes. Do the cassette deck door too while you are at it.
    The service manual is available for download for silver and gold members - well worth the membership fee. Going for gold will also include you in the monthly prize draw. Check the main website to see this months prizes !
