Latest post 05-09-2008 1:07 PM by nobby. 13 replies.
Page 1 of 1 (14 items)
  • 05-05-2008 1:42 PM
    Motor stand for MX7000
    Could anyone tell me if it is possible to use a motor stand MS 4106 on my MX 7000 TV or does some one have a stand for a MX7000 who could photograph the adaption plate so I could fabricate a new one ?
    The MS 4106 looks identical to the MX 7000 unit but the fixings to the TV will be different.
    Jack
  • 05-05-2008 1:56 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Motor stand for MX7000
    Jack, I believe the motor unit is the same on all MX, LX, LS and L models. It is just the plate that is different. They all seem to have the same connection for the motor.
    CraigSmile
  • 05-05-2008 2:44 PM In reply to
    Slight correction ... the MX8000 and MX4200 stands operate differently and there seems to be a compatability issue with some MX5000 stands.
    Neil
  • 05-05-2008 3:19 PM In reply to
    Thanks Craig
    The motor stand does work with the MX7000 I just need details for the adaption plate.
    Jack
  • 05-05-2008 3:28 PM In reply to
    • Craig
    • Posts 4,855
    Jack, it might be worth dropping Nobby a PM knowing Neil, he may have the one you need in stock.
    CraigSmile
    BTW, it was nice to see you again over the weekendWink
  • 05-05-2008 3:30 PM In reply to
    hi jack,
     i have one in front of me, i can add a photo if it helps,
    do you have the smaller mx4000 version to compare to? if not ill check it against one i have in the showroom tomorrow, the holes for the motor will be the same, let me know what measurments you need
    jason
    jason
  • 05-05-2008 5:02 PM In reply to
    Jason
    Thanks for your reply, the stand I have is off a LS5500 , a photo would allow me to see where the screw connections are located.
    Thanks again
    Jack
  • 05-05-2008 6:12 PM In reply to
     no problem jack, the 4 raised holes on the edges fit the tv and the 6 small holes in the centre fit the motor,
    hope this is what your after, or as craig said im sure Nobby should have one if you need one
    regards jason
    jason
  • 05-07-2008 6:12 AM In reply to
    Thanks Jason
    The photo is a great help, I have a MX7000 TV. Could you measure the overall width and length if the plate and the measurement from the turntable centre to the front edge of the plate.
    The centre distances of the mounting holes would be very useful.
    Thanks for all your help
    Jack
  • 05-07-2008 9:27 AM In reply to
    No need to measure, this is the correct one for the 28inch MX
    Neil
  • 05-07-2008 3:42 PM In reply to
    Neil
    I did not realise that you were "Nobby" perhaps I should read my mail with more care.
    I assume that you do not have plate for sale?
    If not the dimensions would allow me to esimate the Centre of gravity of the TV
    Thanks again
    Jack
  • 05-08-2008 4:20 AM In reply to
    Hi Jack,
    Yes, one and the same :o)
    I didnt find a plate yet only a complete motorised floor stand and it would be criminal to break it up.  I have a few more sources to try.
    Neil
  • 05-09-2008 7:56 AM In reply to
    Neil
    Thanks for your reply, I would be interested in buying the whole unit if you cannot locate a replacement mounting plate.
    Perhaps you would want my existing unit ?
    Jack
  • 05-09-2008 1:07 PM In reply to
    I usually retail these at £70.  Can take yours off your hands, but to be honest, unless you are going to collect, it could start to get expensive with the postage.
    You might be better off waiting for one to come up on ebay.
    Cheers, Neil
