Latest post 05-04-2008 10:28 AM by Alex. 3 replies.
Page 1 of 1 (4 items)
  • 05-04-2008 6:27 AM
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    Ripserver-What do you Think?
     Don't know about you guys, but I would love something connected to my Bvis 7/Mac mini/masterlink system that would take the hassle out of ripping cds/dvds and provide a large storage capacity.
    Have stumbled accross this product and would be interested in your thoughts;
    http://www.ripfactory.com/ripserver.html
    regards StUrrock
  • 05-04-2008 7:50 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Ripserver-What do you Think?
    There shouldn't really be any hassle RE ripping CDs if you access your iTunes account over a network, and use a more convenient computer for ripping CDs than your MacMini (which I assume is pretty tied in to the BeoVision).
     Weekly top artists:
  • 05-04-2008 8:46 AM In reply to
    Looks easy to use but I would consider ripping to lossless now that storage is so cheap.  This defaults to 320 MP3 which is fine (and actually what I use!) but if starting again, I would go lossless. If you don't want to go wireless, an external large HDD would seem the way to go - you can rip via one computer and then attach it to the Mac Mini.
  • 05-04-2008 10:28 AM In reply to
    • Alex
    • Posts 2,990
    Networking the MacMini up to another computer which can act as a 'ripping terminal' is actually very simple.
    Two choices - you can either keep all the media on the MacMini or the 'ripping terminal' - I personally would keep it on an external HDD connected to the Mini.
    Connect to the Mini's external drive over a network (wireless or wired, it shouldn't make any difference other than speed), make sure the 'ripping terminal' computer is running under the same user name as the MacMini, and open the MacMini's 'iTunes Library' data file on the ripping terminal. Then in the ripping terminal's iTunes Preferences, choose the same directory the data is stored in on the MacMini as the iTunes folder.
    Don't run iTunes on the Mini at the same time as the ripping terminal - that'll cause serious issues...
     Weekly top artists:
