Latest post 05-03-2008 9:01 PM by Piaf. 2 replies.
Page 1 of 1 (3 items)
  • 05-02-2008 10:48 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Growling Beocord 9000
    Today I noticed that my Beocord 9000 “growls” while in the stop position.
    The recorder performs splendidly in ALL aspects, but it makes a growling noise at pause or stop.
    Once the timer puts everything into a “sleep” mode, the growl stops.
    What is this and is this a cause for concern? If so, what do I do about it?
    Thanks.
    Jeff
  • 05-03-2008 1:16 PM In reply to
    Re: Growling Beocord 9000
    Jeff:
    2 things comes to mind.
    1) Failing motor
    2) Worn/dirty capstan bearing
    Dismantle tape deck and remove the main belt coupling the motor to the flywheel. Turn the deck on.. if it still "growls" its the motor. (B&O has a replacement you can buy but I am told it is not as nice as the original one).
    If it is a worn/dirty capstan bearing, it may need replacement or lubrication.
    Those are my guesses... Martin may know better.
    Derek
  • 05-03-2008 9:01 PM In reply to
    • Piaf
    • Posts 409
    Derek,
    Thank you very much. I had assumed that it was something like that. I will take a look in the very near future. I am “betting” that it is the motor.
    Right now I am in the middle of trying to find out what is wrong with my much loved Beogram 4000.
    If I get through with it in a reasonable period of time, I will tackle the Beocord 9000.
    Thanks again for the advice!
    Jeff
