Latest post 05-04-2008 1:38 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 05-02-2008 9:34 AM
    • runt
    • Not Ranked
    • Joined on 04-02-2008
    • Posts 9
    • Silver Member
    BEO 7007 RECORD DECK PROBLEM
    HI ALL NEED SOME HELP THE ARE WILL NOT LIFT TO GO ON TO RECORD AND WHEN I LIFT IT ON IT SCATES RIGHT THROUGH HOW DO I GET A PARTS TOO LOOK AT AND IS THERE ANY PHOTOS TO HELP ME CAN SOMEBODY ALSO TELL ME HOW TO GET THE TOP OF TO LOOK AT TAPE RECORDED RUBBER
    THANKS JOHN
  • 05-02-2008 9:41 AM In reply to
    Re: BEO 7007 RECORD DECK PROBLEM
    as a silver member, you have access to the mans -both the user and service manuals are available in the products section for the bc7007.
    i would start there...
    • B&o bottle opener
  • 05-03-2008 12:22 PM In reply to
    • runt
    • Not Ranked
    • Posts 9
    • Silver Member
    when i looked at manual it just had wire diagram
  • 05-04-2008 1:38 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    This issue is the same as in the Beogram 2400 etc.. We had this up many times, even only a couple of days ago. It's a matter of lubrication.
    Do a search and I'm sure you will find something. Maybe we should include this issue in the FAQ?
