Latest post 05-12-2008 4:07 PM by magnushj. 10 replies.
Page 1 of 1 (11 items)
  • 05-02-2008 3:59 AM
    Beocenter 7000 turntable won't start
    I have an intermittent problem with the turntable on my Beocenter 7000
    Most of the  time when I press the PH button the turntable starts normally. Sometimes there is a kind of 'pop' sound then notjhing happens and sometimes nothing at all happens.
    Usually turning the unit onto standby for  a couple of minutes solves the problem.This morning it didn't!
    I am guessing that this might be a capacitor issue (One thing I have learned from Beoworld is most problems on older B&O kit are capactor related!) , but I am not sure what to look at first. Could someone point me in the right direction please?
    Simon
  • 05-02-2008 5:49 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 7000 turntable won't start
    The Beocenter won't react to turntable commands if no record is sensed so maybe the record sensing is bad ?
  • 05-02-2008 5:56 AM In reply to
    Thanks Martin, I hadn't though of that one!
     How would I go about checking it?
     Simon
  • 05-03-2008 5:53 AM In reply to
    I don't think it is the record sensing. I have tried reseat the record etc.
    I turned the power on at the plug this morning and the turntable started spinning and the record arm moved the stylus onto the record while the  unit was still on standby. I pressed PH and stylus lifted and the platter stopped turning. Further preses of PH just cause a loud 'pop' sound from inside the unit.
    Anyone know what might be wrong?
    Simon
  • 05-06-2008 3:51 AM In reply to
    Bump!
    Anyone got any idea what this might be? I think I have eliminated record sensing as when I remove the record press the PH the display flashes and nothing happens, but when I replace the record the display doesn't flash and I get the audible 'pop' but the turntable/stylus doesn't move.
    Simon
  • 05-06-2008 5:16 AM In reply to
    Hello
    After the bump have you tried to do other operations? Does the unit accept other command like radio channel selection (from the buttons 1 to 6) or not?
    Let us know
    Bye
    Eugenio
    Eugenio Colazzo
  • 05-06-2008 5:58 AM In reply to
    Thanks Eugenio
    The unit is still workling perfectly in every respect except for the fact that the turntable no longer starts. It has had this problem intermittently for a while, but now it happens all the time.
    Simon
    NoBit:
    Hello
    Let us know
    Bye
    Eugenio
  • 05-08-2008 4:35 AM In reply to
    please wait, I'll check the electric diagram
    Eugenio Colazzo
  • 05-08-2008 3:19 PM In reply to
    Hello
    I have a one suggestion for You. It is possible that you have a electricity problem in DIN plug. For example check and clear the pins.
    Tomasz
  • 05-12-2008 5:04 AM In reply to
    Re: Beocenter 7000 turntable won't start - another question
    Thanks to everyone for all your suggestions.
    It's working again for now!
    I turns out to be a mechanical problem.
    I remember form years gone by that some turntables with belt drives need a helping hand to get started by pushing them gently round with a finger  on the label if the belt was on it's way out.
    This turned out to need quite definite shove with the heel of my hand , but then it started and played OK. There is however a grinding noise from the turntable whenever it is turning that wasn't there before.
    I am guessing that something needs lubricating (maybe some bearings needing some love and attention) but the only service documentation I can find is circuit  diagrams. Can anyone point me in the right direction towards what may need lubricating please?
    Simon
  • 05-12-2008 4:07 PM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Do NOT grease anything near the big white wheel/gear inside the turntable. I did this myself and that just made things worse. Had to disassemble the whole thing and clean it with electronics cleaner (isopropanol alcohol). The wheel/gear is made from a low friction plastic and does not not need lubrication.
    Cleaning it doesn't hurt though. :)
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
