I've bought my first Beogram! It's a 3400 (the earlier type 5703) without the CD4 circuit installed. Everything seems to work fine except that the table runs slow (at a guess it's about 25rpm). I've replaced the belt, tried adjusting the eddy brake (even taking out the magnets), and cleaning the switch contacts, but none of these has worked.
The speed doesn't appear to change when the 45 switch is pressed either, it stays at the same sub-33rpm speed. I don't know if this could be related.
I've taken it all apart and everything seems to be in order - no broken parts, all the switching levers intact and correctly places. Everything spins freely as well, so basically I'm stumped! It's such a simple turntable electronically. The only parts I can think may need replacing are the 10 ohms resistor and 10nF capacitor, but looking at the circuit diagram I can't see why that would make any difference.
If anyone can shed some light on this, I'd really appreciate it!
