Latest post 04-30-2008 12:47 AM by camshaft. 3 replies.
Page 1 of 1 (4 items)
  • 04-29-2008 3:34 PM
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Beomaster 4500: Lights out at 21.30!
    The Beosystem 4500 that I just got works perfectly, but every night at 21.30 it turns down the lights connected to LC2's. The Beolink 7000 that I got with a recently bought Beosystem 7000, is being repaired by my dealer. Is there any way that I can clear the light programming that is still in the Beomaster 4500 without the Beolink 7000. I have several Beo4's.
  • 04-29-2008 3:41 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beomaster 4500: Lights out at 21.30!
    I'm not sure it works with a 4500, but on the 7000 system, pressing standby and mute together, disables the timers. Might work until you get your remote back.
    Andy T.
    Poor me, never win owt!
  • 04-29-2008 3:44 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks! I'll give it a try. At the moment it's like living in a old fashioned boarding school. Lights out at 21.30 and hands above the sheets.
  • 04-30-2008 12:47 AM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    If you're both desperate and comfortable opening the beomaster you could also pop out the lithium battery and put it back in.  That should clear all memory from the system.
    Austin
    -Austin (resident audiophile skeptic)
