I had the bright idea of using my beosound 1 as an extra link speaker and connected it to my Beosound 3000 via the AUX socket. Of course nothing happened and Chris from B & O Brighton suggested reversing 2 wires in the powerlink cable terminal, which they did for me FOC and all was perfect. I then pulled the 20 mtr cable all through my house and connected it up to find it dead. On inspection I found that pulling it through had broken a lot of the soldered connections in the terminal!! I now do not know what goes where!! Can any one give me a wiring diagram for the terminals and suggest which wires I need to reverse. Thanks Steve
