1st March February 2012
Latest post 04-29-2008 2:01 AM by Tom. 15 replies.
04-27-2008 10:01 PM
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
Not much you can do. How does the signal get in? Do you have big windows? I would go over and talk to him, he probably has the same problem with you. There is always the option of using a range reducer but these are ugly. Cheers JK
beoaus
- Melbourne, Australia
- Posts 445
Yes! I have big windows but he is not home much. He can point at me though I could not effect him. I'd have to point at his apartment over my shoulder and there is a wall between his equipment and mine. He could simply wave towards the window near his couch into our place or from his office etc... Come to think about us its lucky we have a little boy now, antic's of the past may have been a little risque....
PhilLondon
- London
- Posts 2,545
If you just have 1 set, set it to option 4, so it reacts only to link commands. There is a way to set your remote to only sent link commands as well. p.
soundproof
- Posts 2,340
AdiS:kill the neighbour...
What if he's a BeoWorlder? What if it's ... you? Would be fun to reprogram an LC2 to respond to the neighbour's TV-commands. Whenever the neighbour uses the Beo4, the light could come on big-time!
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Just leave a horses head on his pillow, with a Beo4 clenched in it's teeth... He should get the hint
camshaft
- Pennsylvania, USA
- Posts 575
soundproof: AdiS:kill the neighbour...
-Austin (resident audiophile skeptic)
beoaus
- Posts 445
wtlc2zpx: If you just have 1 set, set it to option 4, so it reacts only to link commands. There is a way to set your remote to only sent link commands as well. p.
I have multiple rooms with B&O equipment so I'm not sure if that would work and some of the Beo4's have the old software.
beoaus
- Posts 445
..... On a long shot - Can you disable the BV7 internal IR receiver and have an external one attached away from prying Beo4's...
Tom
- Luxembourg
- Posts 3,175
beoaus:I have multiple rooms with B&O equipment so I'm not sure if that would work and some of the Beo4's have the old software.
I see there is now way you can change the settings of your remotes, so I guess you should try to ask your neighbor if he can.
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Page 1 of 1 (16 items)
