Help!
I am setting up a NOS XTRA Active speaker kit (the one with the round eye that the Beolink 7000 hangs on) with a Beolink 7000, Beolab 3000, and Beosystem 4500. I have connected the XTRA kit with the MCL cable to the speaker 2 connection on the 4500.
Here is what works:
Beolink 7000 with the 4500 in 2 way mode
Pentas connected to the 4500
Mute switch on the XTRA transceiver properly turns on and off the 4500 system remotely, and turns on the Beolab 3000 speakers connected to the MCL 2AV.
Beolab 3000 speaker displays the proper source and volume, and play music.
LEDs work on the round XTRA transceiver.
What doesn't work:
I get the dreaded "no contact" on the Beolink 7000 with the XTRA transceiver. The 7000 does not command the XTRA transceiver. I can not get a response out of the Beo 4 remote either.
The combination of the 2 manuals that came with the XTRA kit and the Beolink 7000 provide a confusing explanation of how to put the 4500 in Active Speaker mode, and set up for Option 2. I think I did all that right.
Can someone help me figure this out? Is there a good reference manual for the whole Beolink 7000/Master Control Link setup?
Thanks! Gregg
