Latest post 05-02-2008 7:44 AM by dp. 6 replies.
Page 1 of 1 (7 items)
  • 04-26-2008 9:59 AM
    • dp
    • Not Ranked
    • Joined on 06-28-2007
    • Posts 47
    Masterlink with CAT5: IT WORKS! eh kind of..
    ok since my last post didn't get much response maybe this is of interest to people:
    I have succesfully got Cat5 linking a BeoVision 7 and BeoSound 3200 (cat5 in walls, with RJ45 wall sockets, with lexcom RJ45 to Masterlink cables connecting the B&O to the wall)
    I get full control and it sounds & works great.
    However when I try the same with an active kit it don't work at all :(
    Any ideas why? what's the difference between the ML in a TV or Hi-fi and the ML in an active/passive box?
  • 04-26-2008 12:48 PM In reply to
    Re: Masterlink with CAT5: IT WORKS! eh kind of..
    I have never played with a Lexcom system, but I would guess as CAT 5 only has 4 pairs of wires meaning 8 wires and MasterLink signals are 9 active wires plus ground then they are likely to have not used pin 3 of the Masterlink which is "ML Sense" which is not used in a lot of products but may well be used in Beolink Active.
    I suggest you check to see which wires on the Masterlink cable are connected to the Lexcom system.
    Regards Keith....
  • 04-26-2008 1:19 PM In reply to
    • dp
    • Not Ranked
    • Posts 47
    A bit tricky as the excom is terminated in a RJ45 meaning its difficult to see what's what when it connects to a wall socket!
    I suppose I'm lucky enogh to get the TV and Hi-fi working together. I just didn't realise the active/passive kits were different than the TV and hi-fi's - I though ML was the same !
    I'll update if anything improves...
  • 04-26-2008 1:27 PM In reply to
    Why not check with a multimeter which pins of the Masterlink are connected to the RJ45.
    I notice from the user manual on the web that they use mains earth as their signal return meaning pin 3 is the most likely connection missing.
    Regards Keith....
  • 04-26-2008 6:17 PM In reply to
    As I remember CAT 5 don't have a screen used for ground, that very BAD (lexcom cable is CAT 7). 4 pairs is ok because white/blue and pink use the same +5V, when a connection box or original b&o lexcom cable are used. BL active need the ML sense to work.
  • 05-02-2008 5:58 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    I am using the Lexcom cables as well. Beolink Passive works.
    BUT - I got Cat 7 cabling in the house (ML distribution box in the server room), see pictures in one of my posts.
    So, this might be the issue...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 05-02-2008 7:44 AM In reply to
    • dp
    • Not Ranked
    • Posts 47
    In my previous post to this I mentioned the reason for having all this hassle was because he only had CAT5 and BOSElink cable in the walls.
    Well we've managed to convert the Boselink to masterlink Wink
