Latest post 05-02-2008 9:27 AM by magnushj. 1 replies.
Page 1 of 1 (2 items)
  • 04-25-2008 5:57 PM
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Avant stand noise
    Just got an Avant with very low use.  The stand however is a little noisy when turning.  Is there any sort of maintenance (Cleaning, Lubricating, tension adjustments, etc.) that can be done to the internal components of the stand?
    -Michael
  • 05-02-2008 9:27 AM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Avant stand noise
    Just dismantle it and have a look. Smile It is very simple. Four allen screws to detach the stand from the frame, and then just one torx screw to dismantle it. All underneath the stand.
    The stand is actually a big ball bearing. If something has gotten inside i guess it could make a noise.
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
