Latest post 04-23-2008 1:28 PM by Beobird. 4 replies.
Page 1 of 1 (5 items)
  • 04-22-2008 6:35 PM
    Substitute for Beolabs
    Hi Guys
     Was looking around to see if there were any good substitutes for Beolabs, preferably some that hang nicely on the wall like the old 3500's 4500's
     Also, if you buy speakers of different brand but still active/powered do you need any other cables or will the speaker cables do?
  • 04-23-2008 2:42 AM In reply to
    • Razz1971
    • Not Ranked
    • Joined on 03-25-2008
    • Copenhagen, Denmark
    • Posts 66
    • Gold Member
    Re: Substitute for Beolabs
    Hi Adam.
    There is a company, basaed i Switzerland or Austria that makes active speakers directly compatible with B&O products.
    Piega I think is the name. But I have only seen one model of speaker from them, a free standing floor speaker...not what you are looking for i think. But just to say that you can get other brands to play with your B&O of any kind.
    Razz
    Beocenter 1, Beosound 1 and high hopes for more to come.
  • 04-23-2008 9:48 AM In reply to
    The only company I know off that produces powerlink enabled amplified speakers that are of good quality is Detoma in Germany.
    www.detoma.com
    As any of these are kind of out of my budget, I resorted to making my own.......
  • 04-23-2008 11:13 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Not sure if you're aware of these - they could be right up your street - unfortunately they're passive.
  • 04-23-2008 1:28 PM In reply to
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    The new B&W XT serie will be active and wireless Smile (the xt 2 is smaller)
     Piega is good, but not active. You can also look at Revox (Swiss made hifi). They also have room systems etc.
    Schönberg speakers look crazy, but I don't know if they're active
    I would prefer a pair of b&o 4500's
    We Can't Get Enough B&O Stuff...
