Latest post 04-23-2008 3:50 AM by barkersoldbean. 4 replies.
Page 1 of 1 (5 items)
  • 04-22-2008 5:22 PM
    beomaster 5000
    I apologise for asking such a daft question - but here goes.
    After many months of searching I have finally purchased a beomaster 5000 amp/receiver and want advice on speaker connectors.
    What are they, what is the polarity, where do you get them from?
    I am desperate to get it working this weekend with my old B&O turntable.
    Tony
  • 04-22-2008 5:31 PM In reply to
    Re: beomaster 5000
    Congratulations on your new Beomaster, and welcome to Beoworld!
    Any decently equipped store that sells electronic components should have the connectors. Ask/search for "2-pin DIN plugs". The flat connector is negative, but the polarity doesn't actually matter as long as you connect both speakers the same way. And don't make a short circuit!
    -mika
  • 04-22-2008 5:32 PM In reply to
    Re: beomaster 5000
    You do mean the 80s model? They are 2 pin DIN plugs. The pin is positive and the blade negative. I check on the model as the 60s Beomaster/Beolab 5000 has a somewhat complicated speaker set up.
  • 04-23-2008 3:49 AM In reply to
    Re: beomaster 5000
    many thanks indeed - will get some from an electronics shop today.
    Looking forward to getting it hooked up.
    Tony
  • 04-23-2008 3:50 AM In reply to
    Re: beomaster 5000
    many thanks for the reply - will be doing it this weekend!
    Tony
