Latest post 04-22-2008 5:44 PM by Alex. 1 replies.
Page 1 of 1 (2 items)
  • 04-22-2008 5:13 PM
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Some mac help please?
    Greetings,
    My client has a Mac desktop (can't remember the model, but it is about 6 months old), BeoPort with current BMLink software, and BeoSound 4 (plus a couple of link rooms).  For some reason, when she switches to listen to computer audio from websites, it locks her BeoPort music down after a couple of minutes, then you have to reset the system.  Also, BS4 must be running before she can activate NMUSIC.  I am used to being able to start NMUSIC from a link room with BS4 in standby.  All the BS4 sources work well throughout the system, but as soon as you try to use the Mac, problems.  I switched out the BeoPort; no change.  I checked all the links and junction boxes.
    I am completely frustrated as I have never had this type of problem, and with a number of Apple/BeoPort systems. Any ideas?
    Also, what would you recommend as the correct Apple product to bypass BeoPort in a link system and still use Beo4?  I would rather buy her a product than continue like this.  She already has Airport Express.  Embarrasing.
    Thanks for your help.
     Ray
  • 04-22-2008 5:44 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Some mac help please?
    She can use the AirPort express with a BeoVision - the STB controller software can now blast out the IR codes needed to operate the AirPort Express (they're labelled as Apple TV I believe, although all of Apple's products are cross-compatible).
     Weekly top artists:
