How is the plastic cover of the very bottom base removed???
We need to clean and polish under them....
thanks,..
Held on with double sided tape I believe. There is every chance that you will destroy the silver if you take them apart!
Regards Graham
Thanks Graham...
So, difficult to take apart and clean below???yes??
we've got dirt underneath....the plastic...
