Hi All,
Not visited the site for a while, and WOW
 big changes!! Still finding my way round. Good to see Beoworld lives on.
I just recorded some old LPs onto the SD card on my Beosound 4, using the A.Aux input. I stopped the recording at the end of each side of the LP, then started again after flipping the vinyl. So I now have an A.Aux folder with several sub folders, each sub folder being one side of the LP.
Trouble is when I play them back, I can't find a way of "fast forwarding" through the timing on any one sub folder. If I press the >> button on the BS4 the SD card moves to the next main folder. Same thing on the Beo 4. If I press the ^ arrow on Beo 4 it skips to the next sub folder on the A.Aux recording. Anybody figured out a way to fast forward through a recording?
Crazy thing is I could fast forward through an LP from the comfort of my chair 15 years ago with a Beogram 9500
 That's progress for you.
Please don't tell me I need to stop & start the recording between each track on the LP.
Tony
