Latest post 05-06-2007 9:07 AM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 05-05-2007 3:56 PM
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    DVB-T - Beovision 6
    Does anybody know if the DVB-T module for the BV6 is coming out this month? I've been waiting for months (since Nov 06 I think), everytime I ask I get "it's been delayed". But isn't it (basically) the same as is currently found in the BV9? I assume that works fine, so what's the problem?
    The analgue signal in my area gets turned off in 2011 (I think), any chance of seeing the module before then?
    Ian
  • 05-05-2007 4:09 PM In reply to
    Re: DVB-T - Beovision 6
    Which BV6 do you have? You do know it does not fit the 22" model? It is not quite the same as the one in the BS3 and I am afraid it has been delayed again! Promised for beginning of June from what I have been told. For some reason it is only the UK market version that is having problems. It is also rather expensive....
  • 05-05-2007 4:16 PM In reply to
    • Ian
    • UK
    • Posts 132
    It's OK Peter, I have a 26".
    Given the use/advertising over digital TV in the UK, and that flak that B&O will take when the BV8 launches without it (plus not even an option), If I was Mr B&O I would put everything I can in to getting it sorted - It is almost suicidal commercial behaviour.
    Ian
  • 05-05-2007 4:29 PM In reply to
    I agree. Also the cost will to an extent be swallowed up in the purchase price whereas it seems a bit pricey compared to a STB. I must confess to being a Sky user and of course the DVB-S available in other countries does not work with Sky. I have a feeling the problem at present lies with the Top up TV card which will be part of the package options. I think they are just making sure it all works perfectly before releasing it.
  • 05-05-2007 6:23 PM In reply to
    Hmmm, well i've been waiting for this for over a year and yesterday my local dealer told me it had been delayed yet again for another 2 months!!
  • 05-06-2007 8:58 AM In reply to
    It was my understanding that Top Up TV no longer issued cards to new subscribers,having now launched the Anytime service which requires a (new) dedicated PVR.
  • 05-06-2007 9:07 AM In reply to
    Possibly the reason for the delay?
