Latest post 04-21-2008 12:51 PM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 04-21-2008 11:46 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Some basic Link advice
    One area of my B&O knowledge that is completely lacking is what bits and bobs do I need to acheive the following
    Room 1 (bedroom) - Beomaster 6500 + CX100s + Cona
    Room 2 - (bathroom) CX50s.
    I want to be able to
    a) switch between the two sets of speakers (and also have the option of running both sets at the same time although this is not critical)
    b) be able to adjust the volume of the speakers in room 2, from room 2.
    I have 2 beolink 1000s one for each room
    I can run cables/wires under the floorboards of the 2 rooms
    What do I need?
    Cheers
    Nigel
  • 04-21-2008 12:15 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Some basic Link advice
    Nigel there are two ways you can go about this.
    1) By using an Extra Speakers Kit. This will give you full control of the Beomaster from room 2, but if you adjust the volume from one room it will change in both.
    2) by using an MCL2AV and an MCL2P you get full control. Plus you can control the volume in each room independently.
    CraigSmile
  • 04-21-2008 12:30 PM In reply to
    • h1npw
    • Posts 776
    Thanks Craig
    Think the MCL X-TRA Speaker Kit is probably the way to go for me as it sounds cheaper Laughing
    I'm thinking if SWMBO is in bed not wanting to hear what I'm dancing away to in the shower, I can install a simple switch in the speaker cables to the speakers in the bedroom (Can I do this without causing damage to the Beomasters output transistors?)
    What are the wire connections between the Beomaster, relay and transceiver?
    Cheers
    Nigel
  • 04-21-2008 12:46 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Marlow, Bucks, UK
    • Posts 1,688
    When using the speakers in the bathroom it would normally automatically mute the speakers in the bedroom. I guess you could overide it though.
    If you think nobody cares, try missing a couple of payments.
  • 04-21-2008 12:51 PM In reply to
    • Craig
    • Posts 4,855
    h1npw:
    Cheers
    Nigel
    Nigel you connect the Tranciever to the Extra Speakers Kit. You also connect an length of MCL cable from your speaker connection on you Beomaster to the Extra Speakers kit. Then you just connect your CX50's to the kit.
    CraigSmile
