Latest post 05-07-2007 4:43 PM by R Patton. 17 replies.
Page 1 of 1 (18 items)
  • 05-05-2007 1:13 PM
    Lab 6000 Wall Brackets!
    Anyone seen the news?!?
    http://www.beoworld.org/news_view.asp?id=40
    The 6000s are going to look uber sexy now!! cannot wait to see them on the wall!
  • 05-07-2007 4:51 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Lab 6000 Wall Brackets!
    I put that news item on there on Saturday, and was waiting to see if anyone actually read the news!! Huh?
    Top marks Mobe, Gold Star and extra playtime. Big Smile
    Lee
  • 05-07-2007 6:22 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    great news. but the price is very much B&O-like Wink
    I think I will wallmount my 6000-rears...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-07-2007 7:47 AM In reply to
    No probs! least I can do!
    Might be worth having a mail shot when you do add news to all members? a link to the page just to ensure that no one misses anything new etc?
  • 05-07-2007 9:03 AM In reply to
    BeoLink Wireless 1 updateSet-top Box CoverBeoLab 6000 wall bracket
    With the new wall bracket for the BeoLab 6000 loudspeaker, sound has been given a whole new dimension.
    The BeoLab 6000 wall bracket allows you to mount the loudspeaker on a wall, opening up new possibilities for placement in the home.
    The wall bracket is comprised of two parts: an oval ring onto which the loudspeaker is mounted, and an l-shaped bracket that connects the ring and loudspeaker to the wall. The ring and bracket are made of pearl-blasted aluminium, and on the ring is a front plate made of brushed aluminium.
    The bracket allows you to mount the BeoLab 6000 on the wall in a vertical position. The Power Link and mains cables are led neatly and invisibly from the base of the loudspeaker through the bottom section of the bracket.
    Questions and answers
    What colours are available for the BeoLab 6000 wall bracket?
    The wall bracket is only available in one colour, aluminium, to provide an aesthetically pleasing contrast to the BeoLab 6000 colours.
    Technical specifications
    Designer
    David Lewis
    Size (HxWxD)
    25 x 9,6 x 13,8 cm(10 x 3.8 x 5.5”)
    Weight
    0.7 kg (1.5 lbs)
    Material
    Aluminium
    Type number
    2157
    Bang & Olufsen preliminary price (does not include VAT)
    228 Euro per set
     See the attached image file.
    HTH.
    Pedro "Less is more"
    BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 + BeoCom 5
  • 05-07-2007 9:28 AM In reply to
    They look simply fantastic!!
    I wonder is sales for the 6000s will go up as a result? and I doubt they will be getting pulled anytime soon now..
  • 05-07-2007 9:37 AM In reply to
    I really like the look with this.  It reminds me of the BL8000 wall mount seen before on the old forum.  I liked it too, but this one looks better IMO.  NOw if I could only mount them horizontiallyConfused
    Roger
  • 05-07-2007 10:06 AM In reply to
    • Graeme
    • Top 500 Contributor
    • Aberdeenshire Scotland
    • Posts 194
    eduard:
    Can someone give me the link of the BL-6000 on the B&O site, can not find it!!
     here you go
    http://www.beoworld.org/prod_details.asp?pid=778
    Cheers Graeme
  • 05-07-2007 10:08 AM In reply to
    • Ian
    • UK
    • Posts 132
    Is this a new version of the BL6000?, or can you remove the circular base from older models in order to fit the brackets?
    Ian
  • 05-07-2007 10:12 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    R Patton:
    I really like the look with this.  It reminds me of the BL8000 wall mount seen before on the old forum...
    don't know which one you are talking about. but I always liked these ones, though I would not hang my BL8000s
  • 05-07-2007 11:13 AM In reply to
    Ian:
    Ian
    For new and old - the base on the bottom is held  on by 4 small screws iirc so I would imagine you simply fix to the wall bracket as you would the base plate.
  • 05-07-2007 11:26 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    I just hope the wall bracket won't leave scratches to the speaker, so that you can but it back on it's "regular" base if you want to
  • 05-07-2007 11:44 AM In reply to
    • beodim
    • Joined on 04-17-2007
    • Switzerland
    • Posts 130
    Frankly speaking, I don't understand everybody's excitement about this option of placing BL6000 on the wall. At the end BL6000 is designed a floor stand speaker and I can imagine only very few situations where making it hang on the wall would improve the room set-up.
    BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
  • 05-07-2007 12:11 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    if you can lift the speakers by +/- 15 cm by mounting them on the wall, the sound from the 6000s can be improved if they are used as rears, as the woofers are not in the upper half of the column, but in the middle. This can help you if your sitting position is, as on most sofas, quite low and it's back a little higher. In this case, the wall brackets can really be of some use. On the other hand, some people might prefer the "new look" of the 6000s
  • 05-07-2007 2:04 PM In reply to
    • hebo
    • Top 200 Contributor
    • Sweden
    • Posts 305
    I think they look stunning!
    Typical B&O priceingLaughing WANT IT!!!
     BV10
  • 05-07-2007 4:43 PM In reply to
    tom:
    R Patton:
    It was not this version, I believe it was from a B&O store in NY maybe??  The brackets were very similar to the ones for the BL6000, in that they were not upside down as in your photo.  I had heard of installations where 8000's were mounted/bolted to a floor having the appearance of balancing on it's point.  That would be a unique look
    Roger
