If the problem is due to a ground loop,via the Sky box,you will need to ground the box,or disconnect it from the tv to prove the point.
The loop occurs due to the aerial,ml(if fitted?)and scart connections being all common grounds,but not grounded!!
The easiest way to eliminate the possibilty of a loop,is to ground the Sky box.
