Latest post 05-06-2007 9:18 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 05-05-2007 8:32 AM
    Code for Service Menu: Beovision 4 & BeoSystem 3
    i have a Beovision4 65" full-hd and a BeoSystem 3. i need to enter into service menu in order to change color temperature, and image resizing.
    which is the sequenze ?
  • 05-06-2007 4:12 AM In reply to
    Re: Code for Service Menu: Beovision 4 & BeoSystem 3
    i have found the sequence:
    it is. menu 00 GO
    Now i have to move 1 pixel right the image becouse i have a vertical pixel line that allways flickers.
    which is the system menu voice to do this ?
    Then, i have noticed the my television has a "cold white temperature" beacuse everything is blue. It's possible to change temperature color to  9300 K ?
  • 05-06-2007 5:04 AM In reply to
    I think the reason you didn't get a huge number of responses is that very few people outside service technicians will go into the Service menu and alter the settings. The service manual along with the reference manuals for the BS3 are on site but I would advise getting your dealer to set it up for you - this is an expensive set up and you are entitled to have it as you wish. To get to the manuals, which are too big to email, you need to be a silver or gold member.
  • 05-06-2007 8:49 AM In reply to
    ronzino:
    It´s available yet??In Europe??
    Borja
  • 05-06-2007 9:18 AM In reply to
    Yes as far as I am aware.
