tplowman:This helps a lot. I talked to a guy at B&O and he told me to take the bridge out between my mains in and pre out in the back of the amp (NAD) and connect the speakers to the pre out in the back of the amp. I did that but got no signal to the speakers. I am I completely screwing this up?
This would be my prefered solution too.
Did the hum disappear when the other end of the cable was connected?
Do the speakers turn on (LED goes from red to green) when connected to the pre out and music plays?
May be the switches in the BL8000 used to select either PowerLink or Line as an input do not work correctly. Try switching them several times and check if this helps.
