Latest post 04-16-2008 9:29 PM by beoaus. 5 replies.
Page 1 of 1 (6 items)
  • 04-14-2008 10:25 AM
    • timmer66
    • Not Ranked
    • Joined on 03-03-2008
    • Polson, MT
    • Posts 36
    BeoGram 8000 Series
    Hi all,
     Is the BeoGram 8000 series Datalink-compatible with the BeoCenter 9000?
     -Tim
  • 04-14-2008 2:18 PM In reply to
    Re: BeoGram 8000 Series
    Yes!Smile
  • 04-14-2008 2:33 PM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Thanks, Peter!
    -Tim
  • 04-15-2008 3:04 PM In reply to
    Hello all
    But I think that will only play and stop function well working.
    I have Beogram 8002 connected to Beomaster 5000 and when I use return or advice function in the MCP, the Beogram recognize them as stop function.
    Tomasz
  • 04-15-2008 3:42 PM In reply to
    That could be true! Must confess to only ever using start and stop!
  • 04-16-2008 9:29 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Do the << and >> functions work, or is that what you mean? Should move the arm about 8mm in either direction. If it does not work then its just start and stop. There is a B&O tech tip or like on this which also references the later systems.
    beoaus.
