Latest post 04-15-2008 2:59 PM by markiewj. 2 replies.
Page 1 of 1 (3 items)
  • 04-12-2008 5:19 PM
    Beogram CD50 problem
    Could You help me to solve following problem with Beogram CD50?
    When I give CD first time and put play, the Beogram more than half times of use received this CD.
    When I put secont time play, all is OK (in 100% cases).
    _____________________
    PS. Of course original CD.
    Tomasz
  • 04-13-2008 8:38 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram CD50 problem
    It could be this factory fault; After playing a CD with more than apprx 50-55 minutes on it, when loading a new CD the laser block does not move to track zero before the servo times out, then the CD is ejected. One more attempt will allow for the rest of the travel and it will play.
    It seems to occur only in machines within the serial number range 3375001 to 3409009.
    There's an electronic fix for this problem in that you put a 33Kohm resistor in parallel with capacitor 7C801.
  • 04-15-2008 2:59 PM In reply to
    Hello Martin
    I checked the start after when I played firsts minutes and last minutes in the CD.
    I see that this problem is olny when I played the last minutes in the CD and I want play next CD.
    Than You have right!
    Very thanks for you help. I will add the resistor.
    Best Redards
    Tomasz
