Latest post 04-12-2008 12:30 PM by magnushj. 2 replies.
Page 1 of 1 (3 items)
  • 04-12-2008 11:15 AM
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    BC9500 tape question
    Is the tape drive motor supposed to be running all the time? Even when listening to CDs? It is quite noisy!
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 04-12-2008 11:40 AM In reply to
    Re: BC9500 tape question
    Just checked on my 8500 - shouldn't be all that much different?
    Playing a CD from cold, the tape motor stays off. If I switch to tape the motor starts (no surprise there!) but if I switch back to CD then the tape motor stays running. No idea if it times out and switches itself off. The tape motor isn't noisy, just a very faint rustle if I listen up close with the lid open.
    Cheers, Steve
  • 04-12-2008 12:30 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Hm, as you say, it does indeed stay off from cold. The sound I hear must be transformer hum. Probably about time to replace the capacitors.
