Latest post 04-10-2008 11:33 PM by camshaft. 5 replies.
Page 1 of 1 (6 items)
  • 04-10-2008 8:37 AM
    MCL cable for Speaker Link...
  • 04-10-2008 10:06 AM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Re: MCL cable for Speaker Link...
    Hey Keith, do you mean you would get this cable and then put 4-pin Din speakerlink connectors on the ends?
    -Austin (resident audiophile skeptic)
  • 04-10-2008 10:20 AM In reply to
    Yep...that's what i was thinking..
  • 04-10-2008 8:52 PM In reply to
    • camshaft
    • Pennsylvania, USA
    • Posts 575
    You don't need a "B&O" cable then, just a 4 wire cable.
  • 04-10-2008 9:31 PM In reply to
    Hi Austin...thanks...
    Any special specs on the cable....ie use double speaker wire...to give all 4 leads, etc...
    Solid core, stranded....??  i've never seen speakerlink...
  • 04-10-2008 11:33 PM In reply to
    • camshaft
    • Pennsylvania, USA
    • Posts 575
    I'd probably go with something like 4 strands of 16-gauge wire, wrapped together in a plastic sheath, in the same style as the one you gave.  Don't get solid core.  Also, you can get a cable with more than 4 strands and just use 4 of them.  Do you have a picture of the connectors you'll be using?  Because 4 strands of 16-gauge wire may not fit them.
