Latest post 04-18-2008 6:36 AM by mhw. 3 replies.
Page 1 of 1 (4 items)
  • 04-10-2008 7:16 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Beoport - How are images transfered to the Beovision?
    I am thinking about using a Beoport to get my PC music into the B&O Setup.
    If I want to control the Beoplayer from the main room - assuming the Beoport is in a linkroom - do I need more than the masterlink connection from the Beoport?
    In other words: do I need to connect my Beovision in any way to the Beoport (using a tv tuner card?) ?
    Thanks for you support!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 04-10-2008 7:19 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beoport - How are images transfered to the Beovision?
    The BeoPort connects to your computer's audio output and USB. You then run a single MasterLink connection from the BeoPort to your BeoCenter/Sound. The BeoVision itself won't be able to drive the BeoPort without a BeoSound or BeoCenter to go with it.
    Unless you're thinking of getting a BeoSound or BeoCenter, the AppleTV + iTunes route may be a path to look at. You can drive it with your B&O remote as well, plus you can get photos and movies onto your BeoVision.
    Or, your third option is to wait and see what the supposed 'BeoMaster 5' due later this year is going to be like. It sounds very interesting from what I've heard...
     Weekly top artists:
  • 04-10-2008 8:05 AM In reply to
    • kallasr
    • Posts 1,077
    Thanks Alex for the help. So, I got a Beosound Ouverture, but as I remember this one is not N.Music capable, right?
    I might want to look at the apple solution (using an x-box right now as a media player).
    Thanks again!
    Ralf
  • 04-18-2008 6:36 AM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    I'm pretty sure that the Ouverture doesn't support N.Music, sorry...
