Latest post 04-11-2008 1:54 PM by Medogsfat. 5 replies.
Page 1 of 1 (6 items)
  • 04-09-2008 7:08 PM
    • Alfie
    • Not Ranked
    • Joined on 02-09-2008
    • Posts 6
    Extra inputs
    Hi all,
    I have a Beomaster 1900 which of course has only two inputs. I have a B&O CD player which is using the tape input and I need to add a couple of RCA inputs as well. How do I go about this. I realize that I can't add the inputs directly to the 1900. What type of distribution box should I use or build - I will need the circuitry for the latter.
    Alf
  • 04-10-2008 1:54 AM In reply to
    Re: Extra inputs
    This is B&O's answer!
  • 04-10-2008 4:30 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Extra inputs
    Maplins also do a 4 way expander which would require a couple of phono/DIN adapter cables but not difficult to do.
    Chris.
  • 04-10-2008 9:28 PM In reply to
    • Alfie
    • Not Ranked
    • Posts 6
    Re: Extra inputs
    Thank you - my local B&O service centre has a used one of these for sale.
  • 04-10-2008 9:29 PM In reply to
    • Alfie
    • Not Ranked
    • Posts 6
    Re: Extra inputs
    Thanks - I am located in N.America so Maplins is a little out of the way for me. Mylocal B&O service centre has the answer in a used unit.
    Thanks again.
  • 04-11-2008 1:54 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Extra inputs
    Alfie:
    Thanks again.
    Well done - the chances of a B&O service centre having one of these was remote in the least, let alone your local one!
    Chris.
