Latest post 04-08-2008 7:26 AM by maxem. 2 replies.
Page 1 of 1 (3 items)
  • 04-08-2008 5:41 AM
    • maxem
    • Not Ranked
    • Joined on 05-30-2007
    • Posts 5
    Beo4 question
    I have the following setup. Two STBs connected to AV and Decoder on a Beosystem 1. ML to an Avant and a MX 4002. I have three different Beo4 one mk1, one mk2 and one mk3. I can access STB1 with all remotes on all products by pressing DTV/SAT. I can access STB2 by pressing V.AUX on remote mk3 on all products. Here is the problem. I can't access STB2 by pressing V.AUX on the remotes mk1 and 2 on the Avant or the MX4002. Why is this?
    Is there any other command that could access the STB2? For example V.TAPE2 etc.
    Thanks in advance,
    Max
  • 04-08-2008 6:28 AM In reply to
    Re: Beo4 question
    Max,
    This is a difficult problem to logically understand unless your Mark I & Mark II Beo4's have a fault and the same fault.
    I took a Mark II & a Mark III Beo4 and triggered V.AUX and noted the code sent via the IR of both of them and it was
    0001801000130000000158 for both remotes which is correct. Also the code for V.AUX has never changed since day one.
    For test purposes why not swap the cables of STB1 to STB2 so STB2 will now be triggered by SAT/DTV
    Regards Keith....
  • 04-08-2008 7:26 AM In reply to
    • maxem
    • Not Ranked
    • Posts 5
    Re: Beo4 question
    Keith,
    Thank you for your information. I will do the swap this evening to see if I can understand where the problem is. I'll keep you posted.
    /Max
