Latest post 04-19-2008 11:14 AM by Frank Rizzo. 16 replies.
Page 1 of 1 (17 items)
  • 04-06-2008 2:06 PM
    Beocenter 9500
    Bought in mint condition off ebay....sent to Gramaphone shop in denver, colorado for the go over...the replaced belts on the doors, some sockets. the 2 glass panels.....everything worked fine...
    Sent to south america...radio, doors fine...when they put in a CD...it begins to spin...then stops...will not play...
     Any ideas??
  • 04-06-2008 2:14 PM In reply to
    • RayTheWash
    • Top 500 Contributor
    • Joined on 04-16-2007
    • South East London
    • Posts 93
    Re: Beocenter 9500
    are the CD transit screws still in? located underneath the unit.
     Regards
    Ray
  • 04-06-2008 4:08 PM In reply to
    Re: Beocenter 9500
    Are they original cd's or copies?
    Regards Graham
  • 04-07-2008 1:59 AM In reply to
    Re: Beocenter 9500
    ahhhh...i'll check....have to call them tomorrow....
    Will the 9500 not play copies???
    as always...much appreciated...
  • 04-07-2008 3:01 AM In reply to
    Re: Beocenter 9500
    Some copies are a bit dubious!
    Regards Graham
  • 04-07-2008 11:20 AM In reply to
    Re: Beocenter 9500
    Hi Graham...
    They were origional CD's.......
    THey put in an origional CD...door shuts.....hear it spin.....then door opens up after say 5-10 seconds.....will not play cd....
    Ideas??
    Thanks..
  • 04-07-2008 11:27 AM In reply to
    Re: Beocenter 9500
    Dirty laser lens or bad capacitor(s) on servo pcb.
    If cleaning the lens does not sort it I would replace C2103 on the servo pcb which is the board screwed to the underside of the cd mechanism. There are a couple of other electrolytics on the board but this is the main culprit.
    Regards Graham
  • 04-07-2008 11:30 AM In reply to
    Re: Beocenter 9500
    Thanks a ton Graham...!!
    Where are the parts available??   I see PCB numbers in the service manual....but not the "servo pcb"
    Do you know in which part (1-5) service manual....replacement of this is in??
  • 04-07-2008 11:55 AM In reply to
    Re: Beocenter 9500
    Did it work before you sent it to Denver? and did the same bloke look at the Beosound 9000????
    The servo pcb is part of the cd module. The pcb drawings and cd set up procedure are in the manual but I'm not sure what part. It is page 5-13 of the manual.
    The parts are available from any good electronics store. C2103 is originally 33microfarads 16volt but these are hard to come by. I use 47micro 25volt as replacements.
    There have been several other threads on this on the forum if you do a search.
    Regards Graham
  • 04-07-2008 12:24 PM In reply to
    Re: Beocenter 9500
    Hi Graham..so i'm on page 5-13.......and its the Servo PCB 30....yes??
    I don't see any "c" there...but i see the 2101 and 2102......but no 2103....
  • 04-07-2008 2:06 PM In reply to
    Re: Beocenter 9500
    Capacitor 2103 is to the left of the laser output potentiometer and just above the 6101 chip. They are coloured black on the drawing.
    Regards Graham
  • 04-07-2008 3:11 PM In reply to
    Re: Beocenter 9500
    Got it !!!  Graham...do you think we could just change that out to the spec that you noted above without testing?? And give 'er a shot??
    Gracias..
  • 04-07-2008 4:40 PM In reply to
    Re: Beocenter 9500
    Well the experts do say that you should set the laser current and offset up again. If you promise not to tell anybody I'll let you into a secret................
    Regards Graham
  • 04-18-2008 6:25 PM In reply to
    Re: Beocenter 9500
    Hi Graham and others..
     We replaced the C2103 with exact replacement.. still not working..
    I see in the diagram that there is a TR 6108 (BC 338-16) in the same circut and a R 3116...but in the parts sheet , it does not list a R 3116 for specs..
    Any other ideas??
  • 04-19-2008 3:57 AM In reply to
    Re: Beocenter 9500
    Outside my level of expertise I'm afraid. Maybe Martin (Dillen) can help.
    Regards Graham
  • 04-19-2008 6:17 AM In reply to
    Re: Beocenter 9500
    Actually are the values for all resistors between 3108 to 3038 not given as 1 ohm  2% 1/3W ?
  • 04-19-2008 11:14 AM In reply to
    Re: Beocenter 9500
    ahhhh thanks Peter...just saw that...3108 to 3138....are just as you say..
