Latest post 04-06-2008 3:28 PM by Michaelsen. 3 replies.
Page 1 of 1 (4 items)
  • 04-06-2008 10:08 AM
    Ipod connection
    I would like to connection IPod to my system. I have Beolab 3 loudspeakers and Beocenter 2. In addition I use a Beo4 remote control (the older version with Sat, AV and CD).  I suspect the remote control not to be ab le to connect to AUX. I connect the IPod or PC via mini jack to the AUX in in the panel box, but I cannot get the sound in the loadspeaker.
    Any help out there?
  • 04-06-2008 12:25 PM In reply to
    Re: Ipod connection
    Have you added A.Aux to the List on your Beo4?
  • 04-06-2008 1:18 PM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Ipod connection
    Hold inne av-knappen (sluk) på beo4en din og trykk på list. ADD? kommer opp i displayet. Hvis det står noe annet (OPTION? for eksempel) trykker du opp eller ned til du finner ADD?. Trykk GO. Trykk så opp eller ned til du ser A.AUX i displayet, og så GO.
    Du kan nå velge A.AUX fra din LIST-knapp.  Smile
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 04-06-2008 3:28 PM In reply to
    Re: Ipod connection
    Thanks a lot - it works now
